  • 1.  Macro to call up Bank
    Posted 04-02-2019 19:20
    Hi all,
    Is it possible to build a macro to recall a bank? For example, I have a button that if I hit it... it would automatically put bank 1 on me2 and bank 5 on me1.
  • 2.  RE: Macro to call up Bank
    Posted 04-21-2019 09:58
    I don't think you can have a CC that changes the panel like this, but I know you can change the default behavior of the bank buttons. If you go to USER > NEXT > UseSel, you can use the rotary knobs to select the particular buttons on each bank and set them to be Bank 1 and Bank 5 by default. I like to do this to also disable any buttons I don't want my operators messing with. If you're going to leave it that way, you can also pop off the key caps and replace the text underneath.
