Hi Les, I believe I have solved the problem now (fingers crossed). I deleted the second TSL device in the Carbonite (communicating on Port 5727), and the system seems to be stable now. I am still getting correct names and tally information from Tallyman even with the 2nd device deleted. I thought I needed this device set up in order to receive the UMD information, but obviously not! The first device is still set up on port 8900, which is working correctly.
The multiviewer device in Tallyman still has communications set to port 5727, so I believe that maybe this was conflicting with the Carbonite device settings, and only one of these was required?
Not seen any dropouts for a while now, so hoping that this is the answer.
