Hi all,
Wasn't sure where to post this question...but figured since the RossTalk plugin for Stream Deck is found in the Carbonite download area, this is a good place to start.
I just purchased a Stream Deck XL and installed version 4.6.1.12887 of the software on Windows 10. I've downloaded and installed the RossTalk plugin, but every time I try to create a button with a RossTalk command on the Stream Deck, I get a yellow warning triangle with exclamation point every time I press the button on the Stream Deck.
I've read posts here in the Ross community, and watched the Graphite U video discussing the plugin. Still, I can't get a RossTalk command to work.
Any thoughts? Does the plugin not work with the most recent version of Stream Deck software?
Thanks,
Steve
