Is there a way to manually override the effects dissolve state saved into a memory, so you can toggle whether the mem recall dissolves or cuts in/out? I thought I read this, but the only way I can currently do it is to use a separate memory with the same effect, saved without effects dissolve enabled. I need this so I can cut an effect on from ME1 with the keyer set to the same input as the PGM ME 2 and no risk of an errant dissolve, prior to utilizing a dissolve to a two-keyer split screen. However, I want to dissolve back to a full screen keyer after the split.
I thought you could save a mem without effects dissolve enabled, then turn on effects dissolve, recall the mem, and have it utilize the dissolve. This is not working for me on 8.0a.
P.S. When will 9.0 be released? :)
