I am hoping to get to bring a unit home with me so I can work on some videos again....We have been asked to work from home and not go to the office..
Aux 7 Substitutions would end up having -- everything that is supposed to be clean being replaced with MME BkGD since that source would be the same as a MiniME clean feed (which MiniMEs don't have).
So for a "Super" clean you Aux 7 Following ME 2
Aux 7 subs would have Input 1 - Aux 7 - ME 2 CLEAN....basically for all the inputs you would hot punch you need to sub for ME 2 Clean.
Then for ME 1 if you wanted that to also be clean you would sub ME 1 for ME 1 Clean on Aux 7
For a MiniME you sub for it the MiniME Bus and not a clean as that does not exist..
