  • 1.  Mnemonics text change
    Posted 05-10-2019 18:03
    Hi  everyone!
    I'm looking for solution for changing mnemonics text in carbonite panel.
    I've found some ogScript commands for Carbonite in dashboard like: Mnemonic 80440 text, Mnemonic 10 text, Mnemonic 9007 text, etc.
    Can someone give me a hint about the mnemonics numbering logic in that commands?
  • 2.  RE: Mnemonics text change
    Posted 05-28-2019 15:17
    You'll want to use the "set source mnemonic" under the Carbonite device in the tree. Then you set the source to IN:1 for input1, IN:2 for input 2, etc.
  • 3.  RE: Mnemonics text change
    Posted 06-17-2019 18:53
    Ryan suggests using the RossTalk commands for doing the mnemonic changes and that works great.
    To your question about the numbers -- These are OIDs for the sources.  So the numbers are based on creating a Vast Table with spaces incase of future growth.  Physical inputs for example start at like 1000.
    When in DashBoard you can use the CTRL+I to open inspector and click on elements in the UI to see what they have for values.
    For sources -- go to the Buses page.  Click on any of the source buttons when you are in inspector mode and it will open a table to see the source table and the numbers that correspond to each External and Internal source.
