The memory is going to recall how you set it to recall unless you use the attributes to tell it to ignore them. In DashBoard you will find these in the Memory Tab under Store Attributes.
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
