  • 1.  Media Player End Behavior (Freeze Frame vs Reset)
    Posted 02-25-2020 23:12
    How do you control what a Media Player does at the end of a clip?  One of our videos ends in a full screen graphic so I want the carbonite to freeze at the end of the clip.  Most of the time this happens by default, but sometimes the clip immediately resets to the first frame.  I have yet to determine why the carbonite behaves one way or another.
  • 2.  RE: Media Player End Behavior (Freeze Frame vs Reset)
    Posted 02-25-2020 23:41
    The Media Store when it goes Off Air will display the Preview Frame so that you can see what is loaded in the media Store.  When it goes to air(auto play enabled) it will jump to the first frame and then play again.  At the end when it goes off air it will jump to the preview frame again.
