I was wondering if there was anyway of configuring the Carbonite Tally Outputs from within a dashboard script?
I know that I can use the Dashboard 'Panel' interface to do it, but I would like to automate it to follow some router Outputs.
I have some monitors that take GPI Tallies, and have wired them up to the Mixer, and that part works fine. I also have scripts that follow and lookup tally information between the mixer, matrix and some Monitors that take IP tallies, so the heavy work is done.
I'm hoping for something similar to the following, but I've not found anything.
Rosstalk: TALLY 5:15:OnAir (set tally OP 5, to Physical IP 15, while OnAir)
or
params.setParam("Carbonite", 'Tally', 5, 15, OnAir)
I have found something that says 'IPE 1000 TSL Tally Mode 0x1AAB' in the visual editor, but I don't know if that is anything of use.
Is there anything like this? or any way I can achieve this?
Many Thanks
James
