  • 1.  Audio Mixer Compatibility
    Posted 06-25-2019 12:02
    Good day, I need information or list of Compatible Audio Mixers for the ROSS Carbonite Black Solo, I have a problem syncing Audio and Video, I know the Yamaha 01v96 Can solve this, but I need variety.
    Kind regards
  • 2.  RE: Audio Mixer Compatibility
    Posted 06-25-2019 12:33
    Hi Raymond,
    I will like to understand what you mean by compatible audio mixers. But if your objective is to sync audio and video, then I recommend looking for audio mixers with audio delay function. Or any audio device that can delay audio. Of course I am assuming the audio is ahead of the video.
    Having said that, the Carbonite Black Solo introduces a negligible delay to the video signal. If you are using the video signal directly out from the switcher, it should match the timing of the audio.
