  • 1.  Carbonite Solo Audio Crackle
    Posted 02-08-2020 16:42
    Problem experiencing: Installed a Carbonite Solo with two computers using propresenter. When playing clips from Propresenter, at random audio would start to crackle, which crackling would get worse over time. I have 5 venues using the same files and programs with no problem. I have replaced all hardware except the Carbonite Solo and the and audio console. Equipment: I have a two Mac mini’s using ProPresenter both connected to a Blackmagic ultra studio mini (usb-c), connected to a Ross Carbonite solo (sdi). I am taking a program output from the Carbonite solo and dembedding it using an Ampactic de-embedder into a Yamaha TF5. The two Ultrastudios and Carbonite Solo are getting reference from an AJA Sync generator. Troubleshooting: Have swapped sdi cables, de-embedder, sync generator, and Ultra studio. I cannot seem to reproduce, the crackle appears on it it’s own and progressively gets worse. Typically occurs on videos at a 20min in point, however it has also occurred on a shorter 3 minute video. Would love any support you can give. Ross has said it’s not the Carbonite Solo since it’s only passing the audio, not processing.
  • 2.  RE: Carbonite Solo Audio Crackle
    Posted 02-10-2020 18:11
    Use one of the longer clips that is having this issue -- connect the source around the Carbonite....So Barrel the Input cable to the Output Cable that feeds the dis embedder.  Put the clip on loop and see what happens.
    What happens?
