  • 1.  Output Time Stamp
    Posted 01-22-2020 10:40
    We use a Vision switcher that is on software version 18.1h and Overdrive version 12.0.13. I would like to find away to output timestamps to a text file when I run an overdrive coded elements through a custom control. Maybe pick up the file through ftp. Is that possible?
  • 2.  RE: Output Time Stamp
    Posted 01-22-2020 14:38
    The OverDrive server has event logs you could take those are find your events.
    There is no way to specifically do it the way you describe though.
    #Vision
  • 3.  RE: Output Time Stamp
    Posted 01-22-2020 14:44
    Is there anyway to do it?
    #Vision
  • 4.  RE: Output Time Stamp
    Posted 01-22-2020 14:52
    All of those events are logged in the OverDrive Server Logs.  You can see all of those events run and the time they were run at.
    #Vision
  • 5.  RE: Output Time Stamp
    Posted 01-22-2020 17:06
    Thanks that might just work.
    #Vision
