With Version 2 we did add some more Aux Buses to the Mixer..... So you could achieve something similar but not on the exact channels that you want. The ALL MIXES assignment has the MAIN L&R (audio 1/2) / Then it is AUX 1 Pair (audio 3/4) / Aux 2 (5/6) / Aux 3 (7/8) / Aux 4 (9/10) / Aux 5 (11/12) / Aux 6 (13/14) and then MONITOR is (15/16).
Using say Group 3 of the SDI (Channels 9/10/11/12) you would apply Aux 4 and Aux 5 as the means to accomplish this. Just put the audio you want on those two Aux Audio Mixes. On the output you're sending to the De-Embedder put All Mixes. In the De-Embedder select the correct group and or channels..
Hope that helps.
#Graphite#Graphite#Graphite#Graphite
