  • 1.  Recall inclusions on boot
    Posted 07-03-2019 19:14
    I've been trying to set a Carbonite switcher to include MiniMe1 in recalls on boot.
    We're using the MiniME for a two box DVE, and need to make sure crew can recall the correct memories for the show they are doing easily  without having them fumble thru recall settings on dashboard or the control panel.
    I've tried setting the recall state, no luck.
  • 2.  RE: Recall inclusions on boot
    Posted 07-03-2019 19:20
    Once you have the switcher in the exact state that you would like it to be in....ie setup all the ME and MiniME the way you like it.
    Next you will want to to into the RState Menu and setup the MiniMEs that you would like to include now Save the RState.  Also at this point I would save the file set to Disk.
    Now change all of the MEs and MiniMEs to some thing else and press the Recall RState Button....Does it go to the RState that you saved?
  • 3.  RE: Recall inclusions on boot
    Posted 07-03-2019 20:03
    Following that, yes, everything goes to the RState, but not the Memory Recall inclusion settings.
  • 4.  RE: Recall inclusions on boot
    Posted 07-03-2019 20:59
    The memory recall inclusions will not be changed by any kind of a recall....They need to be selected by the user.
  • 5.  RE: Recall inclusions on boot
    Posted 07-03-2019 22:29
    Okay, so no way to change the memory recall inclusions that it boots with? I'm fine with some kind of a global setting.
    I know it is different hardware, but our Carbonite Solo boots with MiniMEs already selected in the inclusions.
