  • 1.  Media Wipe on Vision
    Posted 11-30-2017 19:41
    In Carbonite, it is very easy to work out the media wipe function with the Media key on the panel.
    But how to work out the Media Wipe function on Vision switcher?
    Could someone show me the correct steps to do it?
    Thanks,
    Tony
  • 2.  RE: Media Wipe on Vision
  • 3.  RE: Media Wipe on Vision
    Posted 03-05-2019 19:46
    Something relating to this: I`m soon working with a truck that has an older Ross Vision 1 switcher. We are suppose to do some animated wipes but unfortunately it seems the switcher only has 25 frames / 1 second of recording capacity. Can this be improved by adding memory, and if yes how much does it cost? The swithcers serial number is F585844004.
    #Vision
  • 4.  RE: Media Wipe on Vision
    Posted 03-05-2019 21:55
    Joel -- you need to call tech support for that question about the RAM....They can walk you through finding out how much RAM is in it and what is possible....That said they would be best to get some kind of a server for those like a Tria that can cue and play with Alpha fast..
    #Vision
