  • 1.  Crossover 12 panel to Carbonite Multimedia
    Posted 05-01-2019 11:27
    I own 2 x ROSS Crossover 12's and recently acquired a 2 x ME Carbonite Multimedia with a Carbonite 1A panel.
    Is there a way to network to add the  Crossover 12 panel  into a 2 ME Carbonite (Multimedia)
    to control its ME or a Mini ME bus somehow  -- The Crossover 12  Panel appears externally identical to the
    Carbonite 10 Control panel ..  or is there a software / firmware upgrade path for the Crossover Panel  .. jp
  • 2.  RE: Crossover 12 panel to Carbonite Multimedia
    Posted 06-17-2019 18:57
    The Carbonite Frame only supports a single Panel via a PSL link (serial panel link).
    To add the other CrossOver Panels (yes the CrossOver 12 Panel is the same as the C10 -- as long as those are not SOLOs but the separate panels) you will need to add a CarboNET to each one.  This will allow them to communicate via IP to the Frame.
    After setting those up you would make sure to set each one to be a Satellite panel....The C1A that is connected to the PSL port will always be the Master Panel.  Make sure each C12 panel is set to a Different SAT slot...ie 1 is SAT1 and the other SAT2.
  • 3.  RE: Crossover 12 panel to Carbonite Multimedia
    Posted 06-18-2019 22:58
    That is a fabulous facility to add to my set-up
    Thanks Les for the response  --  jp
