  • 1.  Media Store Numbers
    Posted 07-11-2019 21:21
    I had to let someone else use my tours switcher for a different show last week, so I saved my switcher USB to my computer for extra safety. I'm glad I did because it was wiped by the guy who used it. Everything loaded fine and all of the CC's are working with one exception, but it is across the board. In EVERY CC that uses the Media Store, nothing is being recalled. I can see the media in the Media Manager, but the CC's are just recalling black. So, I know that the switcher creates and uses a MediaDatabase file to give everything a number and it numbers items in the order received. So, is there a way for me to see the number for each file? Is there a way to re-number them so that they appear where they should in the CC's? Or, am I stuck editing my CC's? I can do this, but I'm looking for a potentially faster and less intensive way to accomplish this task.
  • 2.  RE: Media Store Numbers
    Posted 07-11-2019 22:36
    You can change the Media IDs in the Media Manager.
    When you copy the USB you need to make sure that you also copy the Database.  This is a Hidden file so you need to make sure that you are seeing all files.  Then you can copy that as well.
  • 3.  RE: Media Store Numbers
    Posted 07-11-2019 23:22
    Thanks for the quick reply. For now, I've just figured out what the numbers where for each piece by going through the CC's and using deductive reasoning. My director wrote all of the CC's, so I wasn't familiar with them. I am now though!
