  • 1.  Clips Xpression
    Posted 01-06-2018 13:19
    Hit there, does anyone knows a handy way to see the clips countdown in the multiviewer. when you have a separate graphics engineer working on Xpression with clips and titels, the director and directors assistent want to see the countdown on the multiviewer. @ross: can you not embed only the xpression clip countdown into video signal of the clipplayer on the multiview? If this is not working what is the best solution when you work with separate engineers. kind regards Michel Houtenbos Mobicam Netherlands
  • 2.  RE: Clips Xpression
    Posted 01-06-2018 14:58
    This not currently possible. Not sure how to handle this at the moment either. We will have to look into future feature for something like this.
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 3.  RE: Clips Xpression
    Posted 01-14-2019 19:52
    Is there any new about the feature with timecode
    On multiviewer from the clips player ???
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 4.  RE: Clips Xpression
    Posted 01-14-2019 20:01
  • 5.  RE: Clips Xpression
    Posted 04-01-2019 17:57
    Ok, is it then on the roadmap and if whitch version is it plan to be released ??
    Are the roadmap in public share somewhere at the website ???
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 6.  RE: Clips Xpression
    Posted 07-06-2019 00:09
    Has there been any update on this?
    Would be really usefull...
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 7.  RE: Clips Xpression
    Posted 07-06-2019 00:41
    Road maps are not public.  We announce releases usually at NAB and IBC which release shortly there after.  When we release the versions they are posted on the website with links to download them.
    This feature is not a simple one to do.  We just release version 2.2 which has had months spent implementing the Audio EQ and also adding the ME follow system.
    All Feature requests are tracked in a database.
    #Graphite
    #Graphite
    #Graphite
    #Graphite
