  • 1.  Correct method to pop off panel buttons
    Posted 10-17-2019 20:59
    Just got the CB2 panel setup to accompany our Graphite.
    I would like to change out some buttons (replace aux buttons with mini-me buttons).   What's the correct method / tool to pop off buttons?
  • 2.  RE: Correct method to pop off panel buttons
    Posted 10-17-2019 21:45
    Use your fingers... I "flick" them out easily (once you get the technique) and then separate the 2 parts of the button & insert the label.  Sit it back in place (there a correct way round) and push it gently until it re-seats.  You shouldn't have to use much force at all for any of this.
    To change the User buttons the menu path is MENU > User > NEXT > UseSel Buttns. Use the Button/RowBtn knob to select the user button you want to set up and Type and Index knobs to select the function for the user button
  • 3.  RE: Correct method to pop off panel buttons
    Posted 11-05-2019 01:07
    Perfect, thanks Jos!
    Now, how do User settings get saved?   I noticed User is not part of saving a set.  Or do you not save these settings?
  • 4.  RE: Correct method to pop off panel buttons
    Posted 12-12-2019 04:44
    The User button settings are saved in as part of the Personality settings.
