  • 1.  Output SD
    Posted 09-06-2019 16:50
    Hi, there.
    We do have Vision Video Switcher. We do have HD-SDI inputs 1080/50i. Whereas, its outputs are only SD-SDI , can it be changed to HD-SDI? I did not find an option inside the menu to change it.
  • 2.  RE: Output SD
    Posted 09-06-2019 17:21
    What video mode is the switcher operating in?  If you are operating in SD Video Mode then the outputs do not have output Conversion on them.
    If you switch to HD Video processing Mode and your outputs don't support it that has to do with a model of board that was only ever able to do SD video mode.  New Boards are no longer made for Vision so you would not be able to upgrade them unless you found used parts.
    #Vision
