  • 1.  DashBoard - Graphite Crosspoint internal (RossTalk)
    Posted 08-19-2019 22:16
    Hi again!
    I've been looking through the regular documentation trying to find an answer to this one, but I cant find it.
    In DashBoard, I can send a command to "set crosspoint" to out graphite.
    To get input 3 to the ME1 PGM the commande would be:
    rosstalk.sendMessage(params.getValue('Graphite_IPAddress', 0), 7788, "XPT " + "ME:1:PGM" + ":" + "IN:3");
    However I wish to set one of the Xpression Clips channels as the crosspoint!
    I cannot find any example of this anywhere in the documentation or the "help" button when using visual logic to create the "set crosspoint" block either.
    So, is there a way to set the PGM crosspoint to an internal source like this somehow?
  • 2.  RE: DashBoard - Graphite Crosspoint internal (RossTalk)
    Posted 08-21-2019 18:49
    Hi Aleksander,
    The Carbonite/Graphite online help has a list of all supported RossTalk commands:
    http://help.rossvideo.com/carbonite-device/Topics/Protocol/RossTalk/CNT/RT-CNT-Comm.html#topic.RT-CNT
    I believe the ones you're looking for are:
    • XPression (alpha) — XP:channel-number:A (Graphite only)
    • XPression (video) — XP:channel-number:V (Graphite only)
    Hope that helps,
    Rob
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 3.  RE: DashBoard - Graphite Crosspoint internal (RossTalk)
    Posted 01-20-2020 01:09
    So, uhm... Kinda back to this one, and yeah I did read the online help this time.
    The Graphite has 8 SDI inputs, all good, IN1-8. However, there's a 9th input that is HDMI. Though if I try IN:9 as the crosspoint source, nothing happens.
    Anyone with a clue here?
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 4.  RE: DashBoard - Graphite Crosspoint internal (RossTalk)
    Posted 01-20-2020 03:03
    If you use input 13 what happens?
    I will try to look at this tomorrow when I get into the office.
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 5.  RE: DashBoard - Graphite Crosspoint internal (RossTalk)
    Posted 01-20-2020 14:14
    Yes It is Input 13 for the HDMI.  There is some "hard" coding so that if you go between different size Graphites you would always find the HDMI in the same place.
    #Graphite
    #Graphite
    #Graphite
    #Graphite
  • 6.  RE: DashBoard - Graphite Crosspoint internal (RossTalk)
    Posted 01-20-2020 16:32
    Ahhh, yes there we go! That worked perfectly!
    And yeah, I guess it males sense in that way.
    Thanks again!
    #Graphite
    #Graphite
    #Graphite
    #Graphite
