Hello all,
Eventhough I know XPression inside-out, I'm not very familiar with the Carbonite Black, which is why I'm turning to this Community.
I need to put two Custon Controls on the panel of a Carbonite Black. One Custom Control will be used to trigger a scene with a fixed Take ID in XPression and the other Custom Control will be used to clear that layer in XPression.
I have been watching a video on the Carbonite U that explains the link between XPression and Carbonite, but right at the money-shot, it shows the output and I can't see which button he is pressing... (https://youtu.be/vcArfNBzzvU?t=782)
So I can select the Take ID and set up the Channel/Layer selection but I don't know how he triggers the action in the video.
So just for clarity, I have added the XPression as a device to the Carbonite and I have assigned the channel that I need. The link between Carbonite and XPression is working because when I select the key and turn the knob for UP/DOWN, the selection moves up and down in the XPression Sequencer.
So that's all working but I'm hoping somebody here can give me a step-by-step tutorial on how to set up both Custom Controls.
So what I would need to do:
• Create a custum control on Bank 2 Position 1 that will Take the clip with TakeID 2100 on Channel 2, Layer 2.
• Create a custum control on Bank 2 Position 2 that will perform a LayerOff on Channel 2, Layer 2.
• Display the Custom Control Bank 2 on the panel of the Carbonite Black.
I hope someone can help me out.
Thank you in advance,
Ken
