  • 1.  Pinout and specs on carbonite serial panel port?
    Posted 03-16-2021 09:51
    Hello! Is there someone who knows the specs on the PSL port on the carbonite frames and panels? Is it RS422 or RS232, and which baudrate and so on.
  • 2.  RE: Pinout and specs on carbonite serial panel port?
    Posted 03-16-2021 14:53
    Hi The PSL port is the Panel Serial Link Port... This is an LVDS interface and only to be used with the Older Grey Non-IP Carbonite panels.
  • 3.  RE: Pinout and specs on carbonite serial panel port?
    Posted 03-17-2021 09:42
    Thank you for the answer! I understand. My plan was to use a serial to IP converter and back, between the older panel, but i guess the only sensible option then is to use the Carbonet converter?
  • 4.  RE: Pinout and specs on carbonite serial panel port?
    Posted 03-17-2021 12:47
    Correct off the shelf converters will not work...  The Carbonet is basically the "brains" out of the Carbonite Black moved into a box for supporting this.
