  • 1.  Recalling effect rate stored in memory?
    Posted 10-16-2020 17:28
    For some reason I cant get effect recall durations to work from memory.
    Store settings: Recall mode: General - Fx Dissolve, Fx Duration: 180
    Recall settings: Recall Mode: Memory, FX Duration from Memory
    I also have the 180 duration set on the ME panel area on the board before store.
    Problem is when I recall the above, it always uses the current FX duration, not the one in memory.
  • 2.  RE: Recalling effect rate stored in memory?
    Posted 10-16-2020 23:45
    Which Model of Carbonite?
    Which version of software are you running?
  • 3.  RE: Recalling effect rate stored in memory?
    Posted 10-16-2020 23:49
    Managed to escape the shop already today, so don't have software version, but it is the latest (or very close to it, as I did an update within the last several months).  Carbonite (vanilla) frame, the one without AES audio.  8 DVE, 8 AUX.  Thanks Les!
  • 4.  RE: Recalling effect rate stored in memory?
    Posted 10-17-2020 00:28
    When you are back in the shop and can update the exact version number we can have a look to try and recreate it.
  • 5.  RE: Recalling effect rate stored in memory?
    Posted 11-09-2020 20:39
    13.0.4.17417
