  • 1.  Mira playing transitions a couple frames to high
    Posted 07-17-2020 16:59
    We are building out transitions on an 8 channel Mira, for a Carbonite black. Currently the transitions play out a few pixels high, revealing the source switching underneath. Is there a setting in Mira to adjust output Y axis, or does the Carbonite have a setting to accomplish correct output playout
  • 2.  RE: Mira playing transitions a couple frames to high
    Posted 07-18-2020 01:39
    We will need a lot more information.
    How is the system being Genlocked?
    What other equipment is between he switcher and the Mira?
    Second for an issue like this you can always call Tech Support -- 24x7 as we don't charge for support services.
  • 3.  RE: Mira playing transitions a couple frames to high
    Posted 07-18-2020 02:09
    I called supports, it was an issue with frame synch. I added Mira to the Carbonite Frame synchs, and that fixed the issue.
    Thanks Les
  • 4.  RE: Mira playing transitions a couple frames to high
    Posted 07-18-2020 02:23
    So Happy to hear Tech support was able to help you out!!!  Just don't want you "hanging" around waiting for an important response from us on the Forums....
