  • 1.  Acuity + Caprica Bus Map Question
    Posted 02-05-2021 02:39
    Is it possible to have a different bus map on the Acuity and send a different bus mapping to Caprica? I believe this was possible when Acuity talked directly to Overdrive, but I can't remember how it was achieved.
  • 2.  RE: Acuity + Caprica Bus Map Question
    Posted 02-05-2021 18:09
    Hi Mark,
    In the Device Setup of Acuity where you defined the OverDrive Com Port you will have an Extra Option where you get to pick which Bus Map is used for talking to OVD.  So pick the Map you want and edit it for OVD/Caprica and then Make a separate one for using on the panel.
    #Acuity
  • 3.  RE: Acuity + Caprica Bus Map Question
    Posted 02-05-2021 19:14
    Awesome, thanks Les!
    #Acuity
