Hi Ross Team,
I would like to know what protocol does Ross Vision talks to send tally information to 3rd party tally system. Would like to setup tally grid. Does it talk CTP ?
Regards,Muhammad Muzammil Khan
Vision uses the Kalypso Contribution Tally Protocol.
Which tally system are you using? The Probability is high that it has been used with Vision before.
Would like to setup Evertz Tally system with Ross Vision. We do have Translator card can talk CTP to convert into Quartz.
What is the PGM & PRV out of this switcher? Could you please specify the port # of those outputs? SWR size 48x48
On the website in the documentation section for windows there is specific docs for using with the Evertz CTP cards:
https://documentation.rossvideo.com/files/Manuals/Production%20Switchers/Vision/Device%20Setup/Serial%20Tallies/Evertz%207700PTX-CPT%20Translator(4999DR-120A).pdf
Further docs located at this link:
https://www.rossvideo.com/support/product-documentation/vision/
Thanks Les.
Appreciate your help.
Regards,
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
