  • 1.  Carbonite Ultra Clean Feed not working as expected
    Posted 10-23-2020 15:01
    Punching sports on a 2ME Ultra. ME1 (top) is usually game +bug and ME2 I use to transition and run replays/breaks. I've punched a lot of Rosses but most of my experience comes from Grass/Sony world and usually you just set up a clean feed by selexting what ME and Keyer you want to be top and it ignores all after that, so just as a background that's where I'm coming from here. I have clean set as M1:K1 (Which I understand to mean the clean is set before M1:K1 and all that follows M1K1-4; M2:K1-4) however I'm still seeing the key in my clean feed, any advice?
  • 2.  RE: Carbonite Ultra Clean Feed not working as expected
    Posted 10-23-2020 15:56
    Each ME has it's own Clean Feed.
    You are talking about a "super clean" where you want to have a Clean Feed output that has none of the ME 2 Keyers and then when ME 1 is selected on the ME is ignoring the ME 1 and taking ME 1 CLN instead on the ME 2 Clean Feed?
    Clean feed is not a compounded Clean Feed....The one labeled CLN is the PGM MEs CLN and then you have individual Clean feeds per ME that you can select from as well.
  • 3.  RE: Carbonite Ultra Clean Feed not working as expected
    Posted 10-23-2020 16:02
    Understood, it could be a limit of a smaller a switcher too, but is there a way i can get around this? I'm punching it as a I typically have done in trucks for years, but what I'm trying to do is use MiniME to set a clean feed that I can send out to the videoboard guys for their program (no scorebug) but set a separate wipe to trigger on. So I have clean feed punched in on MiniME1, and I'm doing my program and replay CC's. The replay CC triggers a separate wipe for the videoboard guys, but it takes me down to ME2 on my switcher (which is program minus bug)
    This is a little hard to type out but I think you get where I'm going/seeing my problem? TL;DR is there a way to get a global clean? or should I just set another CC on the MiniME that triggers between following clean ME1 and Clean ME2? Trying to rack my brain here....
  • 4.  RE: Carbonite Ultra Clean Feed not working as expected
    Posted 10-23-2020 16:34
    I would build into the CC that is doing the Wipe on the MiniME to then change the sources underneath to either the PGM ME CLN or the ME 1 CLN....
    Essentially building a sub as part of the CC effect?
