Okay -- I totally do not believe that info makes any sense from their website....
2 things -- Make sure you are attaching the Device to the Input that the decoder is on. That is done in the Panel Mini Menu screen. Menu - Config - Input - Next -
Knob 1 will select the source. then on Knob two you click on it to select the device that you setup.
Based on what they have listed for commands I would suggest you setup a "XPN" device and try using the NEXT and READ commands.
I would use this Ross U video as the basis to setup and configure the device... especially turn off the "Roll Clip" option in the device config. you don't need to be sending the next command when taking to air every time :)
