Yes -- Setup your chroma Key...get all its parameters set. Then in DashBoard you can enable the DVE as an additional Parameter.
Or -- While HOLDING down the CHR Key Type Button press the DVE button...This will attach the DVE to CHR Key and now you can adjust it like it was a DVE only Key.
