I've been following the instructions from the online documentation for the switcher to set up tally for cameras I have.
I pick the tally (step3), then the source(step 4), and I want it to trigger on the program bus(step 5).
After I press the Tally Knob (from step 6) it just takes me out to the "Add New" menu and it does not remember anything I did. What am I missing here? Seems like there would be some way to save it? Any help you guys can give would be appreciated.
Scroll the Knob to see what the assignments are...The Click is saving the config that you just setup.
What Frame is this? Which Software version are you running on?
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
