Is there a way to add delay to a video source that can be customized on the Carbonite Black. The multiprocessor input board I believe is only an option on the Acuity, but I was wondering if customized delay can be replicated solely through the Carbonite black.
Frame synchs and DVE keys add a 1 frame delay, but say we need 7 frames. Is there maybe a roundabout way to achieving that effect. This would be used when running sound in a monitor, and then taking that same source full. Right now there is a delay between the two sources.
