Hi, there.
I have been utilising Carbonite for 3 years, and have no any obstacles with Rossvideo products. Whereas, approximately 7months ago I have installed Carbonite Ultra with 1 ME Panel CB, and face a problem. To exemplify, when turning on Frane and Panel it takes too long to have a connection between them. Sometimes connection cannot be acquired between panel and frame , shutting off then on helps to solve the problem.
It is really intriguing what is a reason behind the mentioned problem?
P.S DIP Switch is set to Deafult IP Address on both( Panel and Frame)
P.P.S Connection between Panel and Frame is point-to-point.
