  • 1.  Carbonite Panel Not Auto Following
    Posted 11-16-2020 20:59
    We have a Carbonite Ultra and a 2S panel. The panel is not auto following on the transition area or when I preview an input that has device control. Any ideas?
  • 2.  RE: Carbonite Panel Not Auto Following
    Posted 11-17-2020 01:44
    Hi Ryan,
    So the mini menu on the panel is not following?  Or DashBoard Live Assist is not following?
    Is this only 1 panel in the system?  Is it set as the Master Panel?
  • 3.  RE: Carbonite Panel Not Auto Following
    Posted 11-17-2020 01:46
    Hey Les. Yea, the mini menu on our pane is t following anymore. It’s the only pane on that switcher.
  • 4.  RE: Carbonite Panel Not Auto Following
    Posted 11-17-2020 01:50
    Did you try rebooting the panel?
    What version are you on currently?
    Do you have TeamViewer running on a pc that has dashboard that can talk to the switcher?
