If you don't want to be able to control this with a Memory Recall then you need to go into the Installation Menu and take those outputs out of FlexiMode and "hard assign" them.
When in FlexiMode they allow you to change the "configuration" of the ME Outputs via the ME SEL Menu's Program Assignment Menu and this can be done in Custom Controls and with a Memory Recall.
This enables the operator to break apart the ME on a memory by memory Recall.
#Acuity
