This is probably more for the OverDrive Forum as I think there might be a setting in OVD where you tell it which MEs it can use for Fixed MEs.....
I also Assume you have 4 MEs -- PGM/PST, ME 1/2 for templates and then ME 3 for this fixed use?
Next does ME 3 show that it is "On Air"? Just wondering if that makes OverDrive think that is not available to recall on to?
Also can't remember if there is a setting for Back to Back recalls or On air recalls that is needed for some of this stuff?
You might need to have a little more detail for them and maybe best to just call into Tech support as they could walk your though it maybe.
#Vision
