I am working remotely using a TouchDrive-2 panel, connecting directly to a Carbonite Ultra chassis, but for most Dashboard functionality I am connecting through a Dashboard proxy server for stability and speed. There is a master panel (non-Touch Drive) in the control room I'm connecting to; my panel is designated as SAT-1.
I am finding that while working remotely, I cannot change the bus map on my TD-2 panel through Dashboard; it only gives me the master panel to change. But if I'm in the control room, using the Dashboard computer that is right next to the panel and connected directly - not through the proxy server, I can change the bus map to my SAT-1 TD-2 panel, but not the master panel on Dashboard.
Is there an option I'm missing somewhere? Is this a bug in Dashboard? Or is it a limitation of the Dashboard proxy server use?
We are on the latest Dashboard, Ultra, and TD-2 versions and firmware.
Jeff
Jeff Verhoef
Sr Technical Director & Executive Production Mgr
Diversified onsite at Dow,Inc.
