Hi Kian, could you see if the USB drive is formatted as FAT32?
If the USB drive is correctly formatted as FAT32, and you are unable to move content onto it, I would get in touch with Tech Support (https://support.rossvideo.com/hc/en-us) to troubleshoot this further.
Aaron
Sent: 12-07-2021 21:08
Subject: Carbonite USB content transfer via FTP
Hello all,
I'm having a problem moving content onto the switcher USB using an FTP connection. I can copy content from the USB to the computer through the connection but not the other way around. I've tried the FTP connection on two different machines with same result. I get a gray "no" symbol (circle with cross through) when trying to move items to USB. Any ideas on that? Interestingly, when I first setup this connection more than a year ago, it worked fine. Hadn't used it much since then. If I remove the USB from the frame and connect to a computer it transfers fine as well. That makes me think it is not a USB failing issue...maybe. For reference, logging to USB direct does NOT appear to be turned on under diagnostics. Read this could prematurely wear a flash drive.
Kian Sedighi
