  • 1.  Carbonite FSFC setup
    Posted 03-28-2022 18:06
    Carbonite Multimedia 24 running 15.0.4.18626.
    Made the switch from 1080i 59.54 to 1080p 29.97.MiniME 29.97
    Cameras don't have genlock - 6 cameras total.
    On Inputs 4, 5, 6, I can't select SDI-FS. I had this option in 1080i.
    I'm only using 6 frame syncs total. Other unused inputs have the SDI-FS option available.
    Thanks.
    Dave Marks
    Live Video Producter
    Crossroads Community Church
  • 2.  RE: Carbonite FSFC setup
    Posted 03-30-2022 06:06
    Hi Dave,
    In MiniME 29.97 switcher mode, the number of frame syncs for the Carbonite Multimedia is halved to 12. There are now 3 frame syncs for every group of 6 inputs. Frame syncs can be applied to 3 inputs on BNCs 1-6, 3 inputs on BNCs 7-12, and so forth. So after applying frame syncs on Inputs 1,2,3, there are no frame syncs available for Inputs 4,5,6. Will it be possible for you to move the cameras on Inputs 4,5,6 to Inputs 7,8,9 and apply the frame syncs there?
    Aaron
  • 3.  RE: Carbonite FSFC setup
    Posted 03-30-2022 14:33
    Thanks I figured it out. The manual says the frame syncs are reduced to 12 but I didn't see a description of how it's broken out.
    Dave Marks
