  • 1.  Carbonite Ultra / Touchdrive memory save/recall
    Posted 03-01-2022 14:38
    I'm stuck understanding something. I create a simple effect (example DVE key over background) in an ME. I do the usual store sequence (bank 0, memory 1). Now I clear out the ME  (Store - Local Row) and when I recall that memory (Memory panel Bank 0 - memory 1), it's not complete. I need to go into Memory on Dashboard and tell it to recall a part. In this case, the keyer.
    I just want to store something simple, and recall it without having to go to Dashboard.
    What am I missing?
  • 2.  RE: Carbonite Ultra / Touchdrive memory save/recall
    Posted 03-01-2022 14:50
    Danny it sounds like Attributes are setup wrong...
    There are Recall Side attributes that can over ride the memory.  The Recall side should all be "Orange" so that unless you are intentionally trying to over ride and force each memory they will allow the memory to define their attributes. (Blue = Force to Recall it, Grey = Force to never Recall it and Orange = Do what the memory has stored for this attribute)
    Then in the Store side of the memory system you have attributes for just ON and OFF (Blue and Grey) for what is included into the memory to recall or to leave alone.  When ever you recall a memory these will change to show you what they were set to (also to allow you to modify them then store back to the memory).  Also when you setup your switcher and Store the R-State you get to set your Default Recall and Store Attributes with that Show file ..  There is a good chance that you have some defaults that after you do the "ALL-ALL" reset function they are being reset to what your R-State has set for defaults.
  • 3.  RE: Carbonite Ultra / Touchdrive memory save/recall
    Posted 03-01-2022 17:24
    That seems to resolve my issue as well as some other oddities I was experiencing with general default configurations. I understood the color coding but not how they are configurable in RStore.
    Enjoying TouchDrive and UltrA. I recommend. Flexible and deep or simple and straightforward. It's an operator's choice.
    Thank you.
