Good day, Chris. Its a bit hard to tell, but the video clip you included appears to show that the AFV function is disabled; is that true? If so, the faders won't track because they have no "preset" level to track to. Try enabling the AFV button on the lower left of the fader, then set the audio level and press "AFV Set." Then when you learn a Memory with the source tracked and another with it not-tracked, the fader should jump from infinity to the preset level.
I've learned two different Memories, one with the source tracked and one with it not tracked. With AFV enabled, the fader operates normally. I tested both the virtual DashBoard panel and a physical TouchDrive panel; both appear to operate normally.
Good luck.
Tedd Tramaloni
Sent: 04-12-2021 14:12
Subject: Rave audio Fader Issues
When creating a memory on a Carbonite Ultra using the rave panel, the fader on the rave panel will raise but not raise visibly until touched and then it goes back down to infinity. Is there any way to overcome this.
Chris Sale
IMT
