  • 1.  Save Failed
    Posted 05-04-2021 13:25
    I'm trying to save new custom controls I've built and anytime I try I get a Failed message. I've taken the flash out and put it back in with no luck.
    I don't want to lose all the CCs I've made by restarting the switcher itself. Is there a way to avoid this?
    Thank you!
    #Carbonite​
    Alexa McGlade
    Live Event Producer
    UCF
  • 2.  RE: Save Failed
    Posted 05-04-2021 14:07
    The switcher keeps those in the "working set" so when you reboot it loads from that location in the onboard Flash Memory.  It does not load it from the USB.  So it won't be lost..
    Do you see the USB in media manager?  Are you sure your not out of space?
    Is the USB FAT32 format type?
    Product Manager - Production Switchers
  • 3.  RE: Save Failed
    Posted 05-05-2021 10:07
    Hi Les,
    I can still see the USB in media manager and we still have 30 GB  of space left. The USB is also FAT32 formatted.
    Alexa McGlade
    Live Event Producer
    UCF
  • 4.  RE: Save Failed
    Posted 05-05-2021 11:54
    After you do a Save and it fails .. if you go to the Configuration - Diagnostics menu can you copy the Log Files to USB?
    Also have you only tried to "Save All" or have you tried to Save the individual Groups one at a time?
    If you get the logs donwloaded after the failed save attempt please send those to techsupport so that the can look into them.
