  • 1.  Button Inserts
    Posted 01-25-2022 15:23
    Our custom button insert pack (for Touch Drive) only includes one each of AUX 4 and AUX 5 button inserts and I'd like to map both user button rows the same. Is it possible to get these?
    And my sympathy to the person who installs all these button caps. That is a very patient person.
    Danny
  • 2.  RE: Button Inserts
    Posted 01-25-2022 17:14
    https://documentation.rossvideo.com/files/Manuals/Production%20Switchers/Carbonite/Labels/Carbonite%20Button%20Inserts.pdf
    That template will enable you to print labels using transparency sheets from Avery and a laser printer.
  • 3.  RE: Button Inserts
    Posted 01-25-2022 19:17
    I vote "blah" on this approach since these are generic switcher labels not something like "Dannys Favorite DSK 4".
    But being the case ... what font and size is used. I want to keep our TD looking professional.
    D
  • 4.  RE: Button Inserts
    Posted 01-25-2022 20:04
      |   view attached
    Okay well here are the Kit PDFs and AI Files..  with the inserts all filled in.
    I guess you could use AI versions and then just modify them that way as well..
    Attachment(s)
    pdf
    4880GR-001-01-DR2.pdf   527 KB 1 version
