  • 1.  Virtual Panel Missing
    Posted 09-03-2021 15:42
    I finally updated Dashboard to V 9.2.1 and I no longer have the "Panel" option in my Carbonite tree. Every tutorial I have watched shows "Panel" when the tree is visible. Where did it go? I have a wood-burning Carbonite Multimedia with Frame firmware V 15.0.4.
    Thomas Ingledew
    LONG RUN PRODUCTIONS
  • 2.  RE: Virtual Panel Missing
    Posted 09-03-2021 16:05
    With version 15 we added Multiple connections to fully support Multipanel operations and make Panel link independent.
    Now the standard 5253 port is for the Main Panel
    5255 - Sat 1 Panel
    5256 - Sat 2 Panel
    5257 - SoftPanel (Sat 3 Panel)
    Also this enables each to have their own Personality and Panel Link system.
    See the link here to the section in the online manual regarding it..
    http://help.rossvideo.com/carbonite-02/Tasks/Operation/DashBoard/Connect-Manual.html
    Also the "Manual" can now be reached from the Menu system directly in DashBoard using the "HELP" menu selection!!  hope you like that was a favourite of mine from Acuity and Vision before that!!
