  • 1.  Touchdrive Keyer Priority
    Posted 12-21-2021 15:09
    Hey all, I'm pretty sure this has been asked before on other switchers but eh community layout has changed and I can't search old posts.
    Is there any way to change keyer priority on a Touchdrive? We have a 3 ME and we ran into a problem when ESPN audited us last week. On almost ever switcher I've TD'd on in trucks we usually run graphics like Font 1, Font 2, and Bug in that respective order in the switcher, key 1, key 2, and key 3 (so the order is logical when a  director calls for it), however, CG2 on the Xpression has the bug for ESPN projects and when doing fonts on CG1. the bug watermark stays in becxause it's on CG2 and they don't want the watermark on. We could switch all their graphics so that the bug is on font 1 but it would basically rebuild out their xpression project and have to redo a lot on the switcher also. And if we ever got a dedicated bug box, ideally that would live on key 3 so that key 1 and 2 would be cg 1 and 2, but then the problem would persist of the bug's water mark staying in on top the fonts. Again we could move the bug to key 1 so that it's on bottom, but then Key 1 would be bug, key 2 would be CG1, and key 3 would be CG 2 and that just seems silly, however, if keyer priority can't be changed than we may just be stuck.
    Phil Manley
    Iowa state
  • 2.  RE: Touchdrive Keyer Priority
    Posted 12-21-2021 15:40
    Correct Key Priority is not adjustable currently in Carbonite switchers..
