Les:
This is what I would like and would really be cool feature to add!
When you already have an input that is a Graphic that has an associated Alpha Key (such as my Mac1 input where the corresponding shift channel has my Alpha channel) the switchers KNOWS it has an associated Alpha. Why not have a "hidden" channel that saves the alphas?
Yes, while true that you still need a second channel, when you save a key as a still, it's already pre-programmed to know where that Alpha channel is.
Now, the "key-still" is saved as a fill BUT the associated Alpha is saved in the HIDDEN "Alpha key" Still Store area. The switcher "remembers" which Still-keys go to which alpha's. This way the same function is taking place BUT the switcher memory is making is easier for the user!
You can name this "auto-Alpha-Key-Still"!!!
...And send me a Ross Cup, or hat or screw driver for thinking up this innovative idea! ;)
I am SURE this will be a big hit...
Sincerely,
Fletcher
#Acuity
