I don't think you can do this directly from the switcher.
What you might try to do is use DashBoard and build a custom Panel that has buttons that will send UDP messages to the console to recall the scenes...
https://behringerwiki.musictribe.com/index.php?title=OSC_Remote_ProtocolThen you would be able to setup RossTalk GPI trigger events on the buttons and run the GPI listener in DashBoard to accept a RossTalk command from the switcher that would trigger the button to send the UDP message based on the Behringer wiki...
Product Manager - Production Switchers
Sent: 07-15-2021 17:12
Subject: Connecting Carbonite Ultra to Behringer x32 Mixer
Is it possible to connect my Carbonite Ultra switcher and Behringer x32 mixer over IP, so that I can access the x32's scene/snippets using the switcher's custom controls or my ultritouch panel? I know I could use an Elgato Stream Deck, but I was really hoping to not spend money.
Wil
