Hi David, that is very straightforward. Create an audio wav file at 48kHz sample rate (thats the rate for video) and name it the same as the animation i.e. if the animation is mediwipe001.tga etc. then the audio should be mediawipe.wav. Then simple put the audio file in the same directory as the animation sequence.
When you load the sequence into a store the audio will be automatically loaded with it.
Remember that to playback the audio you need to assign the specific media store as an ANC data source (thats the embedded audio) to a video output, normally one of the MultiViewer outputs.
Let us know if you need more details.
Nigel
