Looping Clips
  • 1.  Looping Clips
    Posted 10-09-2014 13:50
    I've noticed some clips that are in the clip list don't always have the Loop option highlighted as being selectable.
    I try to bypass this by inserting a Play Loop On command in the CC but the clip will only play through and not loop.
    Wondering why this is.
    Running:
    Vision 3 V 16.1d MD
    Blackstorm 1.2.0.239/Dashboard 5.1.0
  • 2.  RE: Looping Clips
    Posted 10-09-2014 19:30
    Favian:
    I believe it is because you are running a Blackstorm. If memory serves the blackstorm loops via the dashboard interface either ON or OFF and not on a clip by clip basis but as a global command. I may be in error I have not used a Blackstorm for awhile.
    #Vision
  • 3.  RE: Looping Clips
    Posted 10-10-2014 13:00
    In Vision you can actually give a clip a loop property so that the switcher will tell the BVS (or other server if supported) to enter into Loop Mode.
    There is a minimum Clip Duration for loop. This is actually meant for other servers that don't offer the loop function and the switcher does the looping. under extra option of the device you should be able to lower this value.
    #Vision
  • 4.  RE: Looping Clips
    Posted 11-07-2014 16:04
    Les,
    Does this apply to the SMS server as well? I've had issues when trying to set clips to loop within the assign clips menu. Whenever a clip is set to loop, it won't play. When it is not set to loop, it plays but I can't get the SMS to loop without manually activating the loop setting on the SMS channel.
    #Vision
  • 5.  RE: Looping Clips
    Posted 11-07-2014 16:14
    What Version of SMS do you have running? I don't think it supports the Loop extension in VDCP that we use with BlackStorm to set the loop. Also what version of Vision do you have? And what Device Driver under extra options for target device do you have running?
    #Vision
  • 6.  RE: Looping Clips
    Posted 11-07-2014 20:22
    David:
    When we had a blackstom connected to a Carbonite I could never get it to loop. I am aware you are using a Vision but I still think it is a blackstorm issue. Since we changed to the Xpression as "the server" no problems looping and has always worked.
    The work around I did was to make two custom controls and nest them into each other.
    IE:
    CC#1
    Load Clip
    Play Clip
    Pause xx sec
    Recall CC#2
    CC#2
    Load clip
    Play Clip
    Pause xx sec
    Recall CC#1
    Hence a loop was achieved.
    Maybe you could do the same with the Vision and your blackstorm. Just a thought. :)
    #Vision
  • 7.  RE: Looping Clips
    Posted 11-07-2014 20:49
    Gordon-- they have SMS not BlackStorm. Much older version. In Vision we do have the Loop command for BVS (we are going to be getting it eventually in Carbonite).
    But I really need the SMS software version, Vision Version and also Target Device your using for SMS (there is more than 1).
    #Vision
  • 8.  RE: Looping Clips
    Posted 11-07-2014 23:48
    Les:
    Sorry about me thinking they were using a Blackstorm...
    [QUOTE]Favian Claro said 4 weeks, 1 day ago:
    Running:
    Vision 3 V 16.1d MD
    I know Vision has the loop command - I use it when I am on that switcher :)
    Since I was under the impression of them using a Blackstorm I though out there the way I was able to loop with it. All I was trying to convey.
    #Vision
  • 9.  RE: Looping Clips
    Posted 12-01-2014 15:07
    Les,
    We're on Vision 16.o and SMS server is on sofware version 4.5.42 - Hardware version Mio8000.
    I'm not on-site, so I can't tell you the device driver version off the top of my head.
    Not a bad idea, Gordon, but I'd love to avoid that added complexity. I'll file that trick away as a last resort.
    #Vision
  • 10.  RE: Looping Clips
    Posted 12-05-2014 19:48
    You should be able to run with the Loop functions. It is probably a driver setting to the older SMS version and this is why it is not going into loop mode.
    #Vision
  • 11.  RE: Looping Clips
    Posted 12-07-2014 00:05
    So the SMS has an older driver or Vision needs a new driver? Any instructions on where to find a newer driver would be appreciated.
    #Vision
  • 12.  RE: Looping Clips
    Posted 12-07-2014 19:54
    In Vision when you set up the remote port for Video Server under Extra Options you select the "target device" There are more than 1 target devices for SMS. Make sure your on the SMSv4.2 I think it is called. Also you can try the BlackStorm target device as I think it was pretty much the same.
    #Vision
