Hi Nigel and Les- we found the delay timing configuration within our XPression software... and we found that while adjusting the delay timing, we were able to shift the keyed graphics *upward* by adding timing delay, but could not bring the graphics *downward* by going into the negative values for vertical timing. Therefore, our problem is not able to be solved... Is there some operation we are missing?
Les- Our board is referencing at 1080i 59.94 and XPression is referencing at 1080i 29.97. There is no oprion available in the drop down box in XPression to change the reference to 1080*i* 59.94 (if that makes a difference), but it has an option for progressive 1080 59.94. Obviously the progressive format would not work for our congifuration.
Any further ideas or information I can provide to help?
-Mario C.
#Vision
